1 - 16 of 16 Posts
Ok, So we have had the JX for two days now...i guess I am either doing something wrong...or do we not have any type of DRLs on our U.S version?? Surely, our JX's have them??
airlaird
airlaird
Its a Nissan thing and I can't understand why they don't included them here in the US but they are mandatory in Canada. If we can't find a dealership here to install them, I think we may be making a trip to Canada since it appears that there are plenty of places to install them up there.
Many people don't like DRL, one of the reasons it hasn't become law. Careful about aftermarket jobs. Factory DRL's typically run a lower voltage to preserve bulb life, cables wear (from higher voltage), and battery drain.
In addition the Xenon lights are never used for DRL's.
Good point yeller...in the past I have always installed PIAA fog lights with the switch in the dash. I simply used those as DRL's
in my older vehicles. I may have to figure something out.....
airlaird
the DRL would be the bulb closer to the middle.
Short answer: no
Long answer: I think there is a relay that only comes with the Canadian models that is needed. However, even if you order and install one, the BCM controls a close signal by switching the ground for this circuit, and the BCM does not do this for the US models. So in absence of reprogramming the ECM or BCM, it just won't work.
That is some info I found on a Infiniti FX forum.
You may be able to get DRL's installed via a separate switch in the dash.
Thanks for the pic. I need to look at my US JX for that bulb. I can't imagine Infiniti goes through too much work to add DRL's. Maybe mine has the capability without an end user switch.
Using Fog Light and Parking Light housing for DRL. I unplugged fog light harness and disconnected parking light.
DRL is always ON when engine running.
1 - 16 of 16 Posts
