How do you adjust the angle?
Just adjust your mirrors in the reverse gear and store it with your driver position switch.
Here's the part from the user manual (Look for Step 6)
Procedure for storing the outside
mirror positions for best visibility when
backing up
An outside mirror position for backing up can be
stored for each memory switch (1 and 2):
1. Set the parking brake.
2. Place the ignition in the ON position. (Do not
start the engine.)
3. Push the memory switch 1 or 2 fully for at
least one second to operate the automatic
drive positioner.
4. Turn the outside mirror control switch to L
(Left).
5. Depress the brake pedal.
6. Move the shift selector to R (Reverse).
7. Adjust the mirror to the desired viewing position for backing up by operating the outside mirror control switch.
8. Push the SET switch and, within five seconds, push the memory switch 1 or 2 selected in step 3.
● The indicator light for the pushed memory
switch will come on and stay on for approximately five seconds after pushing the
switch. After the indicator light goes off, the
selected mirror position is stored in the selected memory (1 or 2).
9. Turn the outside mirror control switch to R
(Right). Repeat the above procedure to adjust the right mirror position and store in the
selected memory.
● When the driver’s seat and outside mirrors
are not in the memorized position, the outside mirror will move with the initial tilt-down
angle.
