1 - 6 of 6 Posts
Does anyone have any info on how to remove the fog light assembly? I can change the bulb via the tiny vents just underneath it, but I need to remove the entire assembly. Thanks!
I just bent the plastic and changed the bulb, was easy compared to the Avalon
I went with a PIAA plasma ion yellow H-11 bulb.. they are great..
There are usually screws are bolts behind the bumper for removing the fog light. If you can't get to them through the fender liner you might have to remove the bumper.
looking to do this. just wondering what plastic are you referring to? Im thinking the plastic located in the fender liner, where the 3 screws are?
nm. figured it out. luckily I have a buddy who has smaller hands. removing the 3 screws from underneath at each side was enough to do the job. the plastic is flimsy enough to bend and move while maneuvering.
1 - 6 of 6 Posts
