Went to refill yesturday, refuel light just came on.
Went to fill up, i could only pump in 40liters of gas in.
It acted like when the tank is full and the pump stops
Vacuum issue?
Anybody experience this?
I have this problem every once in a while. It seems to happen with a specific pump at the gas station we use, and doesn't matter how full/empty the tank is. I end up either turning the pump handle upside down to make it work, or just fill it really slowly. The slow method is probably safer than upside down handle.
Definately try a different pump/gas station to see if this happens again. Sometimes the pump auto-shutoff is overly sensitive.
As strange as this sounds and even though you probably already know this. Make sure the nozzle is all the way in to the tank. If it's half in it'll trigger the auto shutoff. Hope that didn't sound too strange.
