1 - 8 of 8 Posts
When travelling on city streets, at relatively low speed, I'm hearing/feeling a thumping/shuddering from the rear-end. At first I thought it was the bumper cover/splash guards (which flop around) and I have since reinforced them with tie raps to the frame rails.
It almost sounds like a bad shock. However, when I shake/rock the vehicle heavily back and forth (and had an assistant while I try to isolate the sound - I pretty well ruled out the shock) I can hear noises from the suspension linkages and bushings. Does anyone else have this issue.
Please let me know
Thanks
K'nav
Yes i have a similar experience. This has happened 2 times in the last couple of days. I go to step on the gas and I don't get much of anything (feels like turbo lag, and it may have been at the time, I don't recall the rpm's I was at). Well then it feels like the turbo kicks in and the rear end feels like it is losing traction and jumping. Inside the cabin there is a definite sensation of a jumping shake and a thumping noise. (Somewhat feels like launching the car)
I extremely recommend buying a plastic centered waterproof lube a apply and spray and a grease. All revocation areas will have steel on rubberized friction and these kinds of lube last a LONG time and will not rust your bushings.
to dilipkumar is it possible you were in the eco mode...this will give a sensation that there is hestiation almost like a slipping clutch. To alphonso can you suggest a brand or“plastic“ lubricant product. for example do you mean moly or siliconethanks
Problem is solved, it was a broken shock (now replaced under warranty).
I've never heard of a shock absorber breaking on a new car. Did your dealership have any previous experience with other JXs having the same problem? Any idea why it broke?
It was broken in the sense that it was noisy and creaky as opposed to physically cracked or broken off. I suspect that the vehicle hit a pothole and blew the hydraulic fluid and seal. I also feel that this may be the root cause of the braking issue i was having because on rough roads the wheel would bounce/travel up and down causing the abs to kick in.
i was surprised as well since my 2007 Pilot has original shocks and very smooth/quiet
1 - 8 of 8 Posts
