Rear climate control does respond when fan speed is changed. It blows on low almost all the time. Temp takes a long time to change when digital display is increased or decreased. 60 degree air should not be hot ten minutes after temp is changed. Thoughts??
2015 Original SPX AUTOBOSS V30 Elite Super Scanner Professional Autoboss V30 Diagnostic Scanner the Next Generation of Scan Tool English Language autoboss v30 diagnostic tool Online Free Update 3 Years Warranty Support Multi-brand Vehicles
Are you using the rear controls or are you using the dash control? If you select the rear air control on the dash, are you using the drives side controls to change the air/heat settings? It took me a while to get used to it since our Armada controls were different. Again, when you select the rear control on the dash, the drives side red and blue buttons and the fan control will adjust the rear. Otherwise, the rear controls should function independently. If this doesn't work, check with your local Infiniti dealership service department. Let us know what you find out. This is a first for this and the QX60 forum.
