· Premium Member
We just took delivery of our JX and still haven't gone through all the manuals to see how things work. Since we've had several newer Nissans, many of the features work pretty much the same. One thing I can't tell if its working correctly is the Rear Air control button on the dash. It doesn't seem to want to over-ride the rear controls unless you physically turn off the switches in the second row seat area. On the QX and Armada, you could shut off the rear air from up front. I'm wondering if there is something I'm doing wrong, or if the switch is defective. Anyone having an issue with this?
I had that concern too, but it works fine. The button on the dash is always on as long as the rear AC is on. To control the rear AD, when you are in climate, press the rear button and the screen will display rear, you can turn it off or change temperature.
· Premium Member
Got it. I was thinking it was like the Armada and older version of the QX, where you could over-ride the rear controls and lock them out. I do like the idea that the driver's position heat/cool control buttons and fan switch can contro the rear air conditioning. Thanks for your feedback.
