1 - 20 of 36 Posts
Steering Wheel Audio Controls
The steering wheel audio controls are located on the left side of the steering wheel.
With the ignition switch in the ACC or ON position, push the SOURCE switch to turn the audio system on.
This is the Volume control switch. Push the "+" side to increase the volume and the "-" side to decrease volume.
For vehicles with the Navigation system, push the SOURCE select switch to change the mode in the following sequence:
• AM,
• FM1, FM2,
• XM1, XM2, XM3 (satellite radio if so equipped),
• CD/DVD, USB/iPod, Bluetooth Audio, and AUX if these are being used,
• and then back to AM.
Pushing the ENTER button up or down for LESS than 1.5 seconds will increase or decrease the track number in the following modes:
• CD
• IPOD
• USB
• DVD(if so equipped) and
• Bluetooth audio
When in the Sirius XM Satellite or FM/AM radio modes, the same action, pushing up or down on the ENTER button for LESS than 1.5 seconds moves the radio up or down to the next PRESET channel or station.
Pushing the ENTER button up or down for MORE than 1.5 seconds causes the radio to seek the next available station while in FM/AM radio mode.
If in the SiriusXM Satellite mode, pushing the ENTER button up or down for MORE than 1.5 seconds will display the next or previous CATEGORY.
When playing a compressed audio or USB file, this action increases or decreases the folder number.
If you are in the AUX, IPOD, or USB mode and push the ENTER switch IN, the corresponding menu will be displayed.
While in the DVD mode, if so equipped, pushing the ENTER switch IN selects an item from the DVD display.
Discussion Starter · #2 · (Edited)
Headlights and Exterior Lights
The headlight switch is located on the multifunction lever to the left of the steering column.
To turn ON your front parking lights, tail lights, license plate light and instrument panel lights, turn the headlight switch to THIS position. To turn ON the front headlights, turn the switch to THIS position. All the other lights will stay ON.
To turn ON the high beam headlights, push this lever forward. You'll see a blue indicator light illuminate. To return to low beam pull the lever back toward you. The blue light will turn off. To make your high beam headlights flash ON and OFF, pull the lever toward you and release it.
To signal turns, move it upward for a right turn, down for a left turn. When you've completed the turn, the signal cancels automatically. To signal a lane change, push and hold this lever lightly up or down, not as far as for a complete turn. Release the lever to finish signaling the lane change.
Fog lights create a wide beam pattern, focused lower than the headlights. This minimizes reflected light and helps you see better in foggy conditions. To use the fog lights, your headlights must be ON and low beam selected. Rotate the collar to THIS position and your fog lights will come ON. Rotate the collar to the OFF position to return to low beam and deactivate the fog lights. If you turn the high beam headlights ON, the fog lights will automatically turn OFF.
You can preset the headlights to automatically operate based on exterior lighting conditions. To activate this system, simply turn the headlight switch to the AUTO position, then turn on the ignition. To turn the system OFF, turn the headlight switch to any other setting. The Autolight system will also keep the headlights ON for a period of time after you turn the ignition OFF and open any doors. There is a light sensor that controls the Autolight system on the top of the instrument panel. Keep that area clear of papers and other material.
Discussion Starter · #3 · (Edited)
Parking Brake and Indicator
Your vehicle has a parking brake to the left of the brake pedal.
To apply the parking brake, fully depress this pedal. To release, depress the parking brake pedal a second time with your left foot, while your right foot is firmly placed on the foot brake pedal to keep the vehicle from moving.
When the ignition is ON, this indicator light illuminates to show that the parking brake is applied. When releasing the parking brake, be sure the light is OFF before driving.
Discussion Starter · #4 · (Edited)
Instrument Brightness Control
The Instrument Brightness Control Switch is located left of the instrument cluster. Use it to adjust the brightness of the lights on the instrument panel.
Your instrument panel lights up whenever the ignition is ON, the parking lights or headlights are ON, or in the AUTO position.
To increase the brightness, press the PLUS button. To decrease the brightness, press the MINUS button. When adjusting, a BRIGHTNESS indicator will appear on the Vehicle Information Display.
Discussion Starter · #5 · (Edited)
Warning and Indicator Lights
The warning and indicator lights on your vehicle will help you stay aware of many systems and their operation. Use your Owner's Manual to familiarize yourself with all warning and indicator lights. You'll then be prepared to act swiftly when the need arises.
Discussion Starter · #6 · (Edited)
Shift Mode
Shift ranges can be selected manually when the shift selector is placed in the manual shift gate. In the manual shift mode, the shift range is displayed on the position indicator in the meter. While in the manual shift mode:
• Moving the shift selector to the + (up) side will shift the transmission to a higher range.
• Moving the shift selector to the -- (down) side will shift the transmission to a lower range.
Use 6th gear for all normal forward driving at highway speeds.
Use 5th gear when driving up long slopes, or for engine braking when driving down long slopes. 4th through 2nd gears can also be used for hill climbing or engine braking on downhill grades.
1st gear can be used for climbing steep hills slowly, driving slowly, or for maximum engine braking on steep downhill grades.
Remember not to drive at high speeds for extended periods of time in lower than 6th gear. This reduces fuel economy.
Return the shift selector to the D (Drive) position to return the transmission to the automatic driving mode.
Hood Release
To open the hood, pull this HOOD RELEASE handle located below the driver's side instrument panel. The hood will spring up slightly. Outside the vehicle, push this lever at the front of the hood to the side as shown.
When closing the hood, lower it slowly and push the hood down to lock the hood securely into place.
Before driving, look to see that it is latched firmly.
Automatic Climate Controls
The AUTO mode may be used all year round. The system automatically regulates and maintains fan speed, airflow and temperature in the cabin. To turn the system ON, press the AUTO button. The indicator light turns ON when the system is activated.
The AUTO function can be turned OFF by either changing the fan speed or by pressing the DEFROSTER, MODE or OFF buttons. To reactivate automatic control, press the AUTO button.
To turn the entire climate control system OFF, press the OFF button.
Your vehicle has separate temperature control buttons for the driver and front seat passenger. The driver's temperature control will set the temperature for both driver and passenger if the DUAL control is not activated. Press the blue down arrow for cooler air or press the red up arrow for warmer air.
If you want to adjust the passenger side temperature independently from the driver's side, press the DUAL button or press either the blue down arrow for cooler air or press the red up arrow for warmer air.
The passenger's side temperature will be displayed on the monitor. To switch back to driver control, press the DUAL button again.
The DUAL control mode cannot be activated when the defrost is on.
The manual air flow control button provides a choice of airflow outlets. Press repeatedly to cycle through these choices:
• Air will flow from center and side vents.
• Air will flow from center and side vents and foot outlets.
• Air will flow mainly from foot outlets.
• Air will flow from the defroster vents and foot outlets.
Your choices are displayed on the monitor.
To recirculate air inside your vehicle, press this Air Recirculation button; its indicator will light up. This helps A/C efficiency and helps block outside odors from entering the cabin. Press the Air Recirculation button again to turn OFF and this will allow fresh air from the outside to be drawn into your vehicle.
Please be aware that the Air Recirculation feature will not activate while in Defrost mode because allowing outside air to enter the vehicle improves defogging performance.
Press the CLIMATE button on the control panel to turn the display to the Climate mode. Climate control settings can be changed on the screen.
Remote Start (if so equipped)
The remote start operating range is approximately 200 feet from the vehicle.
To start the vehicle remotely:
Press the LOCK button on the key fob. Then, within 5 seconds, press and hold the ENGINE START button for at least 2 seconds.
The engine will start, the parking lights will turn on and the Automatic Climate Control will begin heating or cooling the vehicle depending on the selected temperature.
The engine will run for 10 minutes and then turn off. To extend the time for one additional 10 minute period, press the lock button on the key fob then press and hold the ENGINE START button for at least 2 seconds.
Run time will be calculated as follows:
• The first 10-minute run time will start when the remote start function is performed.
• The 10-minute extension will start immediately after the remote start function is performed a second time.
For example, if the engine has been running for 5 minutes, and you press the ENGINE START button, the engine will run for a total of 15 minutes.
After two remote starts the ignition switch must be cycled from on to off before remote start can be used again.
To start driving after using remote start, depress the brake pedal and press the ignition switch.
The remote start will not operate if:
• The hood is not securely closed
• The alarm sounds due to illegal entry into the vehicle
• The ignition switch is pushed with an Intelligent Key in the vehicle but the brake pedal is not depressed.
• The Remote Start function has been switched to the OFF position in Vehicle Settings of the vehicle information display.
o For additional information, see your owner's manual.
Laws in some communities and states may restrict or forbid the use of remote starters or require a person using remote start to have the vehicle in view. Check local regulations for any requirements.
Discussion Starter · #10 ·
Located between the vehicle's speedometer and tachometer is the Vehicle Information Display. It displays such items as:
• Active System Status (if so equipped)
• Trip Computer Information
• Tire Pressure Information
• Fuel Economy
• Warning Confirmations (if any are present)
• Settings and
• If equipped, Driver Warning and Assistance Systems, such as:
o Forward Collision Warning / Distance Control Assist,
o Lane Departure Warning / Lane Departure Prevention,
o Blind Spot Warning and Blind Spot Intervention
Also displayed in the Vehicle Information Display: Conventional Cruise control, Intelligent Cruise Control (ICC) information (if so equipped), Intelligent Key operation information, and Indicators and warnings.
Use the Vehicle Information Menu button and the MENU CONTROL SWITCH on your steering wheel to change items in the Vehicle Information Display.
The Vehicle Information Menu button allows you to enter the Vehicle Information menu items. To navigate through the menu items, move the MENU CONTROL SWITCH up or down. To change or select an item, press ENTER. To go back to the previous menu, press the BACK button.
One of the Vehicle Information Display modes, is the Trip Computer. To enable or disable it, go to the SETTINGS menu, then select MAIN MENU SELECTION, then TRIP COMPUTER to toggle on or off.
The trip computer displays:
• AVERAGE MILES PER GALLON,
• AVERAGE MILES PER HOUR,
• DISTANCE TO EMPTY and
• ELAPSED TIME.
AVERAGE MILES PER GALLON AND AVERAGE MILES PER HOUR shows the average fuel consumption and the average vehicle speed since the last reset. To reset both features, push this switch for longer than 1.5 seconds.
DISTANCE TO EMPTY provides you with an estimation of the distance that can be driven before refueling.
When the fuel level is low, a warning will display on the screen.
ELAPSED TIME provides you with actual driving time since last reset.
Discussion Starter · #11 ·
Power Lift Gate
Your vehicle is equipped with a power lift gate. To operate the power lift gate, your shift selector must be in PARK.
To open, push the POWER LIFT GATE switch on the instrument panel, the POWER LIFT GATE button on the Intelligent Key or the lift gate OPENER switch on the lift gate for more than one second. The hazard lights flash and a chime sounds.
The lift gate will open, even if your doors are locked, if you use the instrument panel switch or your Intelligent Key. Your lift gate will also close automatically if you push the switch on the instrument panel or the Intelligent Key.
You'll find the POWER LIFT GATE MAIN switch on your instrument panel. When this switch is in the OFF position the lift gate OPENER switch and the POWER LIFT GATE switch on the lift gate will not operate.
If your battery is discharged and the power lift gate cannot be opened, remove this cover at the bottom of the inside of the lift gate. Beneath the cover is a lever. Move it to the right to open the lift gate.
To close the liftgate, push the POWER LIFT GATE switch on the instrument panel, the POWER LIFT GATE button on the Intelligent Key or the lift gate switch on the lift gate for more than one second. The hazard lights flash and a chime sounds until the liftgate closes.
Do not drive with the lift gate open. Always check to make sure it has closed completely to prevent it from accidentally opening while on the road. For more information on lift gate safety, see your Owner's Manual.
Discussion Starter · #12 ·
Adjustable Head Restraints / Headrests
Your vehicle's seats may be equipped with adjustable head restraints and headrests that may help provide protection against injury in certain accidents.
The head restraint or headrest should be placed so its center is in line with the center of the ear.
To raise the head restraint or headrest, pull up. To lower, press and hold the LOCK button while pushing the head restraint or headrest down. Please refer to your Owner's Manual for further details.
Discussion Starter · #13 ·
Seatbelt Height Adjustment
The front and second row outboard seat belts can be adjusted to the position best for you.
To adjust the seatbelt height so that the shoulder seatbelt passes over the center of the shoulder, simply press and hold the button on the shoulder belt anchor located above the seatbelt on the pillar. Move the anchor to the desired position and release the button to lock the shoulder belt anchor into position.
The belt should be away from your face and neck, but not falling off the shoulder.
Discussion Starter · #14 ·
Automatic Door Locks
For safety and convenience, your vehicle is equipped with automatic door locks.
All doors lock automatically when the vehicle speed reaches 15 miles per hour, and unlock when the ignition is placed in the OFF position.
The automatic door unlock system can be deactivated, however, the doors will not unlock when the ignition switch is placed in the OFF position. To unlock doors after deactivating automatic door locks, pull the inside lock knob or push the power driver's or front passenger's door unlock ICON.
Please refer to your Owner's Manual for detailed instructions on how to deactivate automatic door locks.
Discussion Starter · #15 ·
Power Moonroof
To operate the power moonroof, place the ignition in the ON position.
To fully open the moonroof, push this switch toward the OPEN position. To fully close it, push the switch toward CLOSE.
To partially open or close the moonroof, push the switch in either direction while it is moving.
To tilt the moonroof up, first close the moonroof then push the switch to the TILT UP position and release it.
To tilt it down, push the switch to the TILT DOWN position. Open and close the sunshade by sliding it forward or backwards. If you've turned the ignition OFF and notice the moonroof is open, you still have a period of time in which to close it. However, if either front door is opened during that period, power to the moonroof is cancelled.
If the moonroof does not operate properly, perform the following procedure to initialize the moonroof:
1. Turn ignition switch ON.
2. Press and hold the moonroof tilt switch forward until the moonroof stops.
3. Release the moonroof switch.
4. Press and hold the tilt up switch within 6 seconds.
5. The roof glass will Tilt-Down, Slide-Close, Slide-Open, Slide-Close, Tilt-Up, Tilt-Down.
6. Release the switch. Initialization is complete if the moonroof operates normally. If it doesn't operate normally, see your Infiniti retailer for service.
Discussion Starter · #16 ·
Power Seat Adjustments
Look for this switch on the side of your seat. Simply slide it forward or backward and the seat will move in that direction.
This switch can also be used to adjust the height and angle of the seat. Move the front or rear end of the switch up or down to adjust the angle of the cushion. Then push down or pull up on the middle of the switch to adjust the height.
To recline the seat, push this switch backward until you achieve the desired position. To bring the back upright, push the switch forward.
If so equipped, the lumbar support feature provides lower back support to the driver.
Move the switch forward or backward to adjust the seat lumbar support.
If a child safety seat is installed on the passenger's side of the second row, you can still enter the third row without removing it.
For easy access to the third row seats, pull up on this lever on the second row seatback. This will release the seatback, tilt the seat, and then release the tracks allowing you to slide the seat forward or backward.
To return the seat to a locked position, push the upper seatback rearward until the seatback and track are locked.
To fold the 2nd row bench seat flat, first lower the head restraints and remove the center head rest. To remove the center head rest, push and hold this lock button while moving the head rest in an upward direction. Store the head rest properly so it is not loose in the vehicle.
Next, stow the second row seatbelts in the seatbelt hooks found on the sides of the vehicle.
Then, lift up on the RECLINE lever on the side of the outboard seats near the bottom seat cushion, and fold the seatback flat.
To return the second row seats to an upright position, push up on the seatback until it latches in place.
To fold the 3rd row seats flat,
• pull this strap to release the head restraint.
• Stow the seat belts in the seat belt hooks, found on the sides of the cargo area.
• Then pull up on the latch in the upper corner of each seatback and lower the seatback.
To return the third row seats to an upright position, pull the straps to raise each seatback until secured.
Pull back on the head restraint until it latches. Do not use the pull strap.
Discussion Starter · #17 ·
Automatic Anti-*‐Glare Rearview Mirror (if so equipped)
Your vehicle's rearview mirror has a feature that enables it to detect glare and automatically dim the mirror surface.
The indicator light will illuminate when the anti-glare feature is operating. Press this button to turn this feature on or off.
The automatic anti-glare feature operates when the ignition switch is in the ON position.
Please refer to your Owner's Manual for complete details.
Discussion Starter · #18 ·
Conventional (Fixed Speed) Cruise Control
Cruise Control enables you to set a desired speed between 25 and 89 miles per hour -- and remain there until you wish to slow down, accelerate or stop. To operate the cruise control, push the main ON/OFF switch on the steering wheel to turn the Cruise Control ON. The CRUISE indicator light will illuminate. Accelerate until you reach the desired speed. Then push down on the COAST/SET switch -- and release it. The SET indicator light will illuminate and the vehicle will operate at your selected speed.
If you need to pass another vehicle, assure that it is a legal maneuver, then press the accelerator pedal. Once you have safely passed, simply release the accelerator and your vehicle will return to the previously set speed.
To change to a faster cruising speed, push UP and hold the ACCELERATE/RESUME switch. Release at your desired cruising speed. If you push and quickly release this switch, each push will increase your set speed by about one mile per hour.
To reset at a slower cruising speed, push DOWN and hold the COAST/SET switch. Release when you have reached the desired slower speed. If you push and quickly release this switch, each push will decrease your set speed by about one mile per hour.
To cancel Cruise Control, push CANCEL, or tap your brake pedal. To resume cruising at your last set speed, push UP on the ACCELERATE/RESUME switch. To turn Cruise Control OFF completely, push the ON/OFF switch. When in Cruise Control, please obey posted speed limits.
Discussion Starter · #19 ·
Heated Steering Wheel
The heated steering wheel system is designed to operate only when the surface temperature of the steering wheel is cooler than 68 degrees. If the surface temperature of the steering wheel is above 68 degrees when the switch is turned on, the system will not heat the steering wheel. This is not a malfunction.
To warm the steering wheel your ignition switch must be in the ON position. Push the heated steering wheel switch located on the lower instrument panel, left of the steering wheel. The indicator light will come on. Push the switch again to manually turn off the heated steering wheel. The indicator light will turn off.
If the surface temperature of the steering wheel is below 68 degrees, the system will heat the steering wheel to approximately 86 degrees.
The system will automatically turn off after 30 minutes of operation.
Discussion Starter · #20 ·
Power Tilt / Telescopic Steering Column
Your vehicle is equipped with a power tilt and telescopic steering column, use this switch to adjust the steering wheel to the desired position.
Push the switch up, down, forward or backward to move the steering wheel in the corresponding direction.
If your vehicle is equipped with the Automatic Drive Positioner system, the steering wheel will move up automatically when the driver's door is opened and the ignition switch is placed in the LOCK position.
It will move back into position when the driver's door is closed and the ignition switch is pushed.
1 - 20 of 36 Posts
