in your settings - go to the second last menu on that little screen in between the tach and speedo. You can disable warnings in there.
Thank you but there is not a command in settings to control the screen bertween the speedometer and the tach unless I am misunderstasnding you.
You have to keep going through the menus on the little screen by pressing the button that looks like two squares overlapping each other on the steering wheel (left side) ... if you are having trouble with this - the manual explains it very well (with pictures :) )
Thank You Avishal26 your instructions worked. I really appreciate your help!
Barb
No problem - it took me two weeks to figure out how to reset the odometer and fuel econ on that little screen (which is not linked to the fuel econ and odo on the big screen or the trip odometer) :rolleyes:
