1 - 18 of 18 Posts
2013 Infiniti JX - Back-Up Collision Intervention (BCI)
The Back-Up Collision Intervention (BCI) system can help alert the driver of approaching vehicles or rear objects when the driver is backing out of a parking space. It is always on unless disabled with this button. However, the next time the vehicle is shifted to reverse, the BCI system will again be on.
The BCI system uses radar sensors installed on both sides near the rear bumper to detect an approaching vehicle and sonar sensors to detect objects in the rear.
The BCI system operates when the shift position is in R (Reverse) and the vehicle speed is less than approximately 5 MPH.
When the vehicle is driving in reverse, if the system detects a vehicle approaching from the side or an object in the rear, it provides visual and audible warnings, and applies the brake for a moment.
After the automatic brake application, the driver must continue to depress the brake pedal to maintain brake pressure. If the driver's foot is on the accelerator pedal, the system will push the accelerator upward before applying the brake. If you continue to press the accelerator, the system will not engage the brakes.
Discussion Starter · #2 ·
2013 Infiniti JX - Audio System with Navigation
If your vehicle is equipped with a navigation system, then you are enjoying an AM/FM radio, a CD player, and Sirius-XM satellite radio. If your vehicle is not equipped with navigation, please consult your Owner's Manual for operation instructions.
By pressing the VOLUME ON/OFF knob, you can turn the system ON and adjust the volume.
A radio station can be found manually by turning the TUNE/FOLDER/AUDIO knob left or right to move up or down the dial through the stations. To tune and stop at the next broadcast station, press the SEEK/CATEGORY or TRACK buttons left or right. Up to 18 broadcast and 18 satellite stations can be set into memory. To choose the desired band, use the FM/AM select button for AM1, FM1 or FM2, or the XM button for a satellite band XM1, XM2 or XM3.
Tune to the desired station using manual, SEEK or SCAN tuning. Press and hold any of the desired station memory buttons, one through six until the preset number is updated on the display and the sound is briefly muted. When the sound resumes, the station has been set.
This audio system features Speed Sensitive Volume or S-S-V, which increases volume at higher speeds and decreases it at lower speeds.
To turn ON S-S-V, press this SETTING button.
Select the "Audio" key using the INFINITI controller then press to select; the audio settings screen will be displayed.
Select the minus (-) key or the plus (+) key to change the S-S-V. While in this screen, you can also adjust the other audio settings by selecting the corresponding key.
To adjust Bass, Treble, Balance and Fade, press the audio control knob until the desired mode appears in the display. Turn the tuning knob to adjust Bass and Treble to the desired level. You can also use the tuning knob to adjust Fade and Balance modes.
Once you have adjusted the sound quality to the desired level, press the AUDIO control knob repeatedly until the radio or CD display reappears.
To play a CD, insert the compact disc into the slot with the label side facing up. Automatically, the disc will be guided into the slot and start playing.
If the radio is already operating, it will automatically turn off and the compact disc will play.
When the SEEK or CAT button is pressed while a compact disc is playing, the track being played returns to its beginning. Press several times to skip back through tracks. The compact disc will go back the number of times the button is pressed. To eject a CD, press the eject button.
For information on USB and iPod features, please go to the USB/iPod Interface chapter in the Vehicle Control section.
2013 Infiniti JX - Destination Button
As part of the Infiniti Navigation System, you will be able to search, store and delete preferred locations. The Destination Screen will appear when you push the Destination button. A list of choices will appear on the screen. By touching the preferred type of destination, the next screen will appear. Your choices include:
Searches by street address. In addition to street numbers, the system can use intersections, phone numbers, freeway entrances, and exit points.
Places - using various categories of businesses or locations to determine an address.
Address Book that finds destinations based on the list of locations you have previously stored.
For a complete list of available settings, please refer to your owner's manual.
To find directions to a specific address for the first time, check to make sure the navigation system has the correct region.
To specify the region, press the DESTINATION button.
A map will appear on the screen. Touch the region of the country you wish to locate.
To get directions to a specific address, touch Street Address from the list of displayed choices.
You will see a number pad like this. Type in the house number and touch OK.
You will then be asked to enter the street name. Using the key pad, type in the street name and touch OK.
A series of addresses will appear. Select your destination from the list, by touching the screen. The position of the selected location is displayed in the preview on the right side of the screen.
Please note the Navigation program includes an AutoFill feature. When typing in an address, the system will try to complete the street name or city for you. While this is mostly a convenience feature, you will always want to check that it has made the correct assumption.
The selected location will be displayed on the touch screen. Touch Start to begin calculating a route.
If you want to add destinations to your journey, touch the words "Add Way Point" on the screen. Enter the new locations as you did with the first destination. The system will determine a route including the waypoint you have added.
To delete a destination, push the destination button and touch Next Page. Then, touch Delete Destination.
Storing your Home address can be a real-time saver when traveling. The first time you use this feature, you will need to store it in the special home setting.
To designate a home address, press the destination button, and then touch Home. Enter your address and touch Store. The touch screen will display a confirmation.
In addition to receiving route guidance through the display screen, you may also choose to have voice guidance.
On the Multi-Function Controller, press Settings and on the Screen Display, touch Navigation.
Touch GUIDANCE SETTINGS.
Then, touch GUIDANCE VOICE. The indicator light will illuminate when activated. Touch again to turn the guidance voice off.
Once a destination has been successfully set, you may choose to store the searched location in the vehicle's address book for retrieval at another time.
On the display panel, touch "Store Location".
The location is stored in the Address Book. The corresponding icon containing the address is displayed.
To delete a location completely, follow these steps:
Push the destination icon.
On the display screen, touch "Next Page".
Then touch DELETE DESTINATION.
The screen will display a message asking you to confirm the action. Touch YES. The destination and the waypoints are now deleted.
Please remember once deleted the destination and waypoints can no longer be retrieved.
2013 Infiniti JX - Theater Package (if so equipped)
If your vehicle is equipped with the Infiniti Theatre package with the Dual Head Restraint DVD System, you can enjoy watching video files from either a DVD or CD providing images and sound from both the front and rear display screens.
Using compatible auxiliary jacks, you and your passengers can also play video games, camcorders, or portable video players. For optimum diversity, the front display and the rear displays can use independent video and audio sources. Use the remote controller that comes with the system to operate the rear display screens.
As a safety feature, the front display will not be available while the vehicle is moving and the remote controller cannot be used in the front seat.
To see images, the shift selector must be in the P or Park position and the parking brake applied.
Rear passengers have the option of using wireless headphones that are part of the Theatre Package. On the other hand, you may choose to connect your own wired-headphones by plugging into the headphone jacks located on the back of the center console. Once plugged in, control the volume through the control knob by turning to increase or decrease the volume.
To set up the wireless headphones, first press the switch located on the headphones to the ON position. The power LED will illuminate if the battery is charged.
Check to make sure you have selected the correct display channel. For the left- hand side display, the left-right switch on the headphones should be set to the left. For the right- hand side display, the left-right switch on the headphones should be set to the right.
Use the volume control to keep the sound at a comfortable level.
If there is no sound after four minutes, the headphones will automatically turn-off. In addition, the headphones will turn-off after four hours of continuous use. If the audio is not clear on the headphones, it could be due to interference from another communication device. To resolve the problem, you can turn the volume down or stop using the headphones. The wireless headphone system will function only in the rear seat.
The DVD feature plays much like the ones used in homes. Passengers in the backseat can enjoy this entertainment option when the vehicle is running. However, the vehicle must be in "P" or Park with the parking brake applied for front seat passengers to view the DVD system on the front control panel.
To begin, press the DISC-AUXILIARY button on the display screen until the DVD mode is present.
When a DVD is inserted, the control options will again be displayed on the screen and will automatically turn-off after a short period. To bring up the operation screen again, press the DISC-AUXILIARY button.
The touch screen will allow you select control functions while the DVD is playing without the operation screen being shown.
Alternatively, you may choose to use the Infiniti controller to select an item from the displayed video.
If you would like to use the remote to watch a DVD, start by choosing the display you wish to control. Slide the L-R switch on the remote to L for the left rear display or R for the right rear display.
If you need to pause the DVD, press the pause key.
To resume playing, press the play key.
To stop the DVD, press the stop key.
To skip chapters either forward or backwards, press the double arrow icon in the direction you wish the DVD to go. The chapters will advance forward or backward the number of times the respective key is touched or selected. See your Owner's Manual for a complete list of commands available.
To connect a video game or other auxiliary device, press SOURCE on the remote control and use the directional keys and ENTER button to choose the appropriate source. If "Rear AUX" is the desired source, slide the L-R switch on the remote to L for the left rear display or R for the right rear display.
Behind the center console are the Input Jacks where you can connect your compatible device.
For more information regarding your system's components, please refer to your owner's manual.
2013 Infiniti JX - Tire Pressure Monitoring System (TPMS)
Your vehicle is equipped with a Tire Pressure Monitoring System (TPMS). It monitors pressure of all the tires except the spare.
When the low tire pressure warning light is lit and the "Tire Pressure Low -- Add Air" warning appears in the Vehicle Information Display, one or more of your tires is low on pressure and air is needed.
The system also shows the pressure of all tires on the display screen by receiving a signal from a sensor that is installed in each wheel.
The TPMS will activate only when the vehicle is driven at speeds above 16 MPH. Also, this system may not detect a sudden drop in pressure such as a tire blowout.
When adding air to an under-inflated tire, the TPMS with Tire Inflation Indicator provides visual and audible signals outside the vehicle to help you inflate the tires to the recommended COLD tire pressure.
First, be sure to park the vehicle in a safe and level place. Apply the parking brake and place the shift selector to the "P" or Park position.
Place the ignition switch in the ON position, but do not start the engine.
Next add air to the tire. After a few seconds, the hazard indicators will start flashing. When the designated pressure is reached, the horn beeps once and the hazard indicators stop flashing.
You can repeat this procedure for each tire.
2013 Infiniti JX - Bluetooth Hands-Free Phone System without Navigation
If you are equipped with the Infiniti Bluetooth Hands-Free Phone System without a Navigation System, you can set up the wireless connection between your cellular phone and the in-vehicle phone module. With Bluetooth® wireless technology, you can make or receive a hands-free telephone call with your cellular phone in the vehicle.
To connect your phone with the Infiniti Bluetooth Hands-Free Phone System, follow these steps:
Press the phone icon button on the steering wheel. The system announces the available commands.
Next, say, "Connect phone". The system acknowledges the command and announces the next set of available commands.
Say, "Add phone". Your command is acknowledged and asks you to initiate connecting from the phone handset.
The connecting procedure of cellular phones varies according to each cellular phone model. If you go to www.infinitiusa.com/bluetooth, you'll find a Compatibility Guide that identifies all brands and models of phones that have been confirmed to be compatible with your vehicle's Bluetooth wireless technology system. If your cellular phone is not listed this does not necessarily mean that it is incompatible, but the website will not be able to offer further assistance for this phone. In this case, please refer to the owner's manual for your cellular phone.
When prompted for a Passkey code, enter "1234" from the handset. The Passkey code "1234" has been assigned by INFINITI and cannot be changed.
The system will then ask you to say a name for the phone.
Once your cellular phone is connected to the in-vehicle phone module, no other phone connecting procedure is required. Your phone is automatically connected with the in-vehicle phone module when the ignition switch is placed in the ON position with the previously connected cellular phone turned on and carried in the vehicle.
You can use the same procedure to connect up to five different cellular phones to your vehicle's Bluetooth.
Here are some helpful tips to get the most out of your Bluetooth system.
Download and follow your phone model's online User's Setup Guide to initiate the system's convenient features, step--by-step.
When using the Bluetooth® system, keep the interior of your vehicle as quiet as possible. Close windows, and direct air vents away from the roof and your face.
Wait until the system tone sounds and the face icon on the display changes before speaking a command.
Start speaking within five seconds after the tone.
Say, "Help" to hear a list of available commands at any time.
Speak in a natural voice without pausing between words.
You can press the VOICE button to skip prompts at any time.
To cancel a voice recognition session, simply wait five seconds say "Cancel" or "Quit" or press and hold the PHONE END button.
To increase or decrease the volume of the phone prompts, push the volume control switches, plus or minus, on the steering wheel or turn the control dial on the audio system if in operation.
When speaking phone book names, please be aware some phones require the last name to be spoken before the first name. For example, "Michael Smith" may be spoken as "Smith, Michael".
For recommended phones and detailed instructions, please visit www.infinitiusa.com/Bluetooth.
2013 Infiniti JX - Route Button (if so equipped)
Once a destination is selected, the Infiniti Navigation System helps to refine your travel plans by finding the fastest or shortest route, minimize freeways, or even, add points of interest along the way.
To change these route settings:
Press the ROUTE button.
Select "Route Settings".
Touch "Basic Route Type".
Touch the preferred route condition.
The indicator for the selected condition illuminates.
When the conditions are set, the system starts calculating the route with your new request, and the current location map screen is displayed.
If you want to cancel a route, the destination will not be completely deleted and available when you are ready to reactivate it. Here is how you can cancel a route:
Press the ROUTE button. A list of route options is then shown.
On the display screen, touch CANCEL ROUTE.
The system will confirm your request to cancel the route, respond by touching YES.
You have the option of canceling a route through voice command as well.
To do so, push the TALK icon located on the steering wheel.
After the tone sounds, speak a command, say: "Cancel Route".
To reactivate the route, press the ROUTE button.
Press RESUME ROUTE.
To confirm your request, touch YES. Reactivating a route only works on the last canceled route.
2013 Infiniti JX - USB/iPod® Interface
This is your USB/iPod interface. It is located in the center console of your vehicle. When a compatible storage device such as an iPod is plugged in, audio files can be played and controlled through the vehicle's audio system. When closing the center console lid, please make sure the cord is routed through this notch to ensure lid closure and cord integrity.
Also, if your device supports charging via a USB connection, its battery will be charged while connected, when the vehicle's ignition switch is in the ACC or ON position.
2013 Infiniti JX - HomeLink® Universal Transceiver (if so equipped)
Your HomeLink® Universal Transceiver's control buttons are located along the bottom of your rearview mirror. The system can consolidate the functions of various individual handheld transmitters to replace devices that operate garage doors, gates, lights, or security alarms. HomeLink® is powered by your Infiniti vehicle's battery and requires no other power source.
Please note that you will need all of your hand-held transmitters, such as your garage door opener, to successfully program HomeLink®.
To get started, you will first clear the memory by pressing and holding the two outer HomeLink® buttons, for 20 seconds, until the indicator light slowly blinks. Then, you can release both buttons.
Now you are ready to program.
To begin programming, position the hand-held transmitter 1 to 3 inches away from the HomeLink® surface.
Now, using both hands, simultaneously press and hold both the HomeLink® button you want to program and the hand-held transmitter button until the indicator light flashes, changing from a slow blink to a rapid blink.
When the indicator light flashes rapidly, both buttons may be released. The rapidly flashing light indicates that the device has been successfully programmed.
To activate a programmed device, press and hold the programmed HomeLink® button. If the indicator light is solid, training is complete and your device should activate when the HomeLink® button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns to a solid light, there are additional steps required to program your device. See your Owner's Manual for more information.
If you have any questions or are having difficulty programming your HomeLink® buttons, please refer to the HomeLink® web site at: www.homelink.com or call 1-800-355- 3515.
Discussion Starter · #10 ·
2013 Infiniti JX - Fuel Functions
Located in the instrument cluster, this gauge indicates the approximate fuel level in the tank. This light comes on when the fuel level is low. Refuel as soon as practical. You'll see an arrow next to the fuel pump icon that indicates on which side of your vehicle, the fuel-filler door is located.
The fuel-filler door automatically unlocks when the driver's door is unlocked. To open the fuel-filler door, simply exit the vehicle, and push the right side of the fuel-filler door.
The fuel-filler cap is a ratcheting type. To remove the cap, turn it counterclockwise. Put the cap in the holder on the fuel-filler door while you are refueling.
After fueling, turn the cap clockwise until a single click is heard, indicating the cap is locked, and then securely close the fuel-filler door.
When you see this message in the Vehicle Information Display, it is letting you know the fuel cap was not attached properly and is now loose.
If this occurs:
• Exit the vehicle and reinsert the fuel-filler cap straight into the fuel-filler tube.
• Turn the fuel-filler cap clockwise and tighten until a single click is heard.
• Now, press the RESET button for more than one second to turn the indicator OFF.
If the cap is not properly tightened, the Malfunction Indicator Light may illuminate.
Discussion Starter · #11 ·
2013 Infiniti JX - Remote Entry
Another feature of the Intelligent Key is the Remote Keyless Entry. From a distance of up to 33 feet or 10 meters, you will be able to lock or unlock all your doors, the fuel-filler door, activate the panic alarm and open the windows.
To lock all the doors and fuel-filler door, push the ignition switch to the OFF position and make sure you take the Intelligent Key with you. Do not leave the Intelligent Key inside the vehicle.
Then, close all the doors and push the LOCK button. All the doors and fuel-filler door will lock and the hazard indicator will flash twice and the horn chirps once.
You can check the door handles to confirm they have been securely locked.
To unlock, just push the UNLOCK button on the Intelligent Key once. The hazard indicator will flash once. The driver's door and fuel-filler door are now unlocked, press a second time within five seconds and all doors will unlock.
To unlock the liftgate, locate the liftgate button on the Intelligent Key, press for more than 0.5 seconds, and the liftgate will open to access to the cargo area.
If you are near your vehicle and feel threatened, activate the alarm by pushing the PANIC button on the key for more than 1 second.
The theft warning alarm and headlights will stay on for a period of time unless any button on the Intelligent Key is pushed.
Discussion Starter · #12 ·
2013 Infiniti JX - Making a Call
To make a call first press the phone icon on the steering wheel.
The "Phone" screen will appear on the center display.
You may then select:
• Vehicle Phonebook, to select the name from an entry stored in the vehicle phonebook.
• Handset Phonebook, to select the name from an entry stored in the handset phonebook and
• Call History, to select the name from the incoming or outgoing call history.
To dial a phone number, push the TALK switch and say DIAL NUMBER.
Then say, the digits of the phone number you wish to call starting with the area code.
Alternately, you can group the numbers into three-digits for the area code, three-digits for the prefix and then the last four-digits. This is a helpful approach when the system has trouble recognizing the correct phone number.
Infiniti also offers a function called the Voice Recognition system that is designed to learn the specific sounds of your voice, making audio requests easier and more accurate.
The Voice Recognition system can memorize the voices of up to three people.
To begin training the system, press the SETTING button on the instrument panel and select the "Others" key on the display screen.
Select the "Voice Recognition" key.
Select the "Speaker Adaptation" key.
Select the user whose voice is to be memorized by the system. Then, you will need to select a category to be learned by the system from the following list:
• Phone
• Navigation
• Information
• Audio
• Help
The voice commands in the category are displayed.
Select a user voice command to train and the Voice Recognition system starts.
Look for the voice icon with its mouth closed, you will hear a tone and the voice icon will change to one with its mouth open. Please repeat a command after the tone. The same command will be on the display screen as well.
When the system has recognized the voice command, the voice of the user is learned.
Then, press the switch or the BACK button to return to the previous screen.
If the system has learned the command correctly, the voice command indicator on the screen turns on.
During a call, you also have some options available to you.
First, press the VOICE button on the steering wheel that will mute the receiving voice and enter commands.
Now, you will be able to use the Voice Recognition function to:
"Hang Up -- to finish the call
"Use Handset" to transfer the call to your cellular phone
"Mute", to mute your voice to the person on the other end of the call and
"Keypad" - brings up a keypad so you can enter digits in situations such as entering your PIN number for voicemail.
Discussion Starter · #13 ·
2013 Infiniti JX - Receiving a Call
To receive a call, press the phone icon on the steering wheel, or touch the "Answer" key on the display.
When you wish to end a call, press the phone icon button on the steering wheel again.
The Voice Recognition Function works best, if you keep these tips in mind:
The vehicle should be as quiet as possible, which means close the windows, and direct air vents away from the roof and your face, and attempt to minimize surrounding noises such as traffic and vibration sounds.
Wait until the tone sounds before speaking a command.
Speak in a natural conversational voice without pausing between words.
If the air conditioner is set to "Auto", the fan speed is automatically lowered to the reduce noise.
It's also possible to switch a call from Bluetooth to your cellular phone's handset. While you are on the phone, several options will be displayed on the touchscreen. Select the "Use Handset" option to transfer the call to your cellular phone.
Discussion Starter · #14 ·
2013 Infiniti JX - Alternate Command Mode (One Step Calling)
The Alternate Command Mode lets you control the Audio and Display systems and provides additional commands for Vehicle Information, Phone and Navigation systems.
To activate the Alternate Command Mode, press SETTING on the instrument panel. Then, select the OTHERS key on the display panel. Select the VOICE RECOGNITION key. Then, select the ALTERNATE COMMAND MODE key. A confirmation message will appear on the screen. Select the OK key to activate the ALTERNATE COMMAND MODE.
When activated, the system does not announce or display the available commands at each step and you can say things like:
• "Call [name]" for example "Call John Smith".
• "Places" for a list of places of interest categories.
• "Weather Information" to show weather information.
• "Traffic Information" to turn the traffic information system on and off.
• [Audio Source] for example "Bluetooth Audio" or "XM" to change source.
When the Alternate Command Mode is activated, an expanded list of commands can be used after pushing the TALK switch. The Standard Mode commands are not offered when the Alternate Command Mode is on display. To find a complete list of commands available, please see your owner's manual. Please note: The voice recognition success rate may be affected as the number of available commands and ways of speaking each command are increased.
The Alternate Command Mode uses specific voice prompts. To become familiar with the commands you can do the following:
Press the Talk switch; listen for the tone and say, "Help". The system will respond by displaying the command list main menu.
Another way to obtain the command list is to press the INFO button on the instrument panel.
Next, select OTHERS on the touchscreen display.
Then, select VOICE RECOGNITION.
For more information on your Bluetooth® system refer to your Owner's Manual or visit www.infinitiusa.com/bluetooth.
Discussion Starter · #15 ·
2013 Infiniti JX - Outside Mirror Control Switch
When the ignition switch is in the ACC or ON Position, you will be able to adjust your outside mirror by remote control.
To begin, move the small switch to the right or left depending on which side you want to adjust.
Using the larger switch, you can then move each mirror to the desired position.
Once the mirrors are in place, return the smaller switch to the Neutral position to avoid accidently changing the mirror positions.
If your vehicle is equipped with the Reverse, tilt-down feature, the selected outside mirror surface will turn downward to provide better rear visibility close to the vehicle.
To use, turn the ignition switch to the ON position and select the left or right outside mirror. Move the shift selector to (R) or Reverse and the mirror will turn downward. Please note: Only one mirror can be adjusted at a time.
The selected mirror surface will return to its original position when any of the following have occurred:
• The shift selector is moved to any position other than R (Reverse).
• The outside mirror control switch is set to the neutral or center position.
• Or the ignition switch is placed in the OFF position.
The outside mirrors along with the rear window glass can be heated to defrost, defog, or de-ice for improved visibility.
Once the engine is started, push the rear window defroster switch. The indicator light will be illuminated on the display screen.
The rear window defroster automatically turns off after about 15 minutes. To turn it off sooner you can push the defroster switch a second time.
Discussion Starter · #17 ·
2013 Infiniti JX - Power Windows
The power windows function when the ignition switch is placed in the ON position and for a short time after the vehicle is turned off. The power is immediately canceled if the driver's door is opened after the ignition switch is placed in the OFF position.
Available on the driver's side is the power window control panel that operates the front and rear passenger windows. Tapping the driver's window switch lightly will partially open the window. To close the window, pull the switch up until the desired window position is reached.
To lock passengers' windows, the driver depresses the window lock button. Push it a second time to cancel the function.
The front and rear passenger's power window control panel operates only the corresponding passenger's window. To open the window partially, push the switch down lightly until the desired window position is reached. To close the window partially, pull the switch up until the desired window position is reached.
To fully open a window, press the window switch down, to the second detent, and release it. The window will completely open. To halt the process, lift the switch up while the window is opening.
To close a window, pull the switch up, to the second detent, and release it. The window will automatically close. To stop the operation, press the switch down while the window is closing.
Please Note: If the vehicle's battery is disconnected, replaced, or jump started, the power window auto-reverse function may not operate properly. If this occurs, please contact an INFINITI retailer to re-initialize the power window auto-reverse system.
Discussion Starter · #18 ·
2013 Infiniti JX - Lane Departure Warning (LDW) and Lane Departure Prevention (LDP) (if so equipped)
The Lane Departure Warning (LDW) and Lane Departure Prevention (LDP) systems (if so equipped) are activated at speeds of approximately 45 miles-per-hour and above. These systems monitor the lane markers on the traveling lane using a camera unit located above the inside mirror.
When the camera detects that the vehicle is traveling close to either the left or the right of the lane, the orange Lane departure warning indicator light on the instrument panel blinks and a warning chime sounds.
When the Lane Departure Prevention (LDP) system is on, it will automatically apply the brakes briefly on the appropriate side of the vehicle to help return the vehicle back to the traveling lane.
You can choose to enable or disable the LDW and LDP systems by performing the following steps:
Press the vehicle information display screen button until the word "Settings" appears.
Select "DRIVER ASSISTANCE" and press enter to select.
Now, select "Driving Aids", and press enter.
To set either system to on or off, use the arrow buttons to navigate through the menu and use the ENTER button to select or change an item.
1 - 18 of 18 Posts
