Spec's for the Infiniti JX35 AWD & FWD are the same aside from the drivetrain difference.
Infiniti JX35 specifications list:
POWER:
Engine
3.5-liter 24-valve V6, aluminum-alloy block and heads. Low-friction resin-coated pistons
Valvetrain
Double overhead camshaft (DOHC), 4 valves per cylinder with microfinished camshafts. Continuously Variable Valve Timing Control System (CVTCS) optimizes opening of intake valves
Intake System
High-flow tuned induction system
Fuel Economy
EPA Estimated Fuel Economy (mpg)[*] (city/highway) 17/23
Horsepower
265 hp @ 6,400 rpm
Torque
248 lb-ft @ 4,400 rpm
Transmission
- Electronically controlled Continuously Variable Transmission (CVT). Manual shift mode offers sequentially selectable manual gearshifts
- Infiniti Drive Mode Selector allows driver to choose between Standard, Sport, Snow or Eco mode and controls throttle responses and transmission mapping Standard Standard
- Snow mode helps driver control throttle response
Drive Type
- Front-wheel drive
- Intelligent All-Wheel Drive (AWD)
Tow Capacity
3,500 lbs
HANDLING:
Steering
Vehicle-speed-sensitive power steering
Suspension
Front – Independent, strut with coil springs over shock absorbers, stabilizer bar
Rear – Independent, multi-link with coil springs over shock absorbers, stabilizer bar
Wheels and Tires
- 18-inch, split 5-spoke aluminum-alloy wheels with 235/65R18 all-season tires
- 20-inch, split 5-spoke aluminum-alloy wheels with 235/55R20 all-season tires – available with Deluxe Touring Package
EXTERIOR FEATURES:
- Automatic-on/off High Intensity Discharge (HID) bi-functional xenon headlights with wiper interlock and manual levelizer
- Integrated front fog lights
- LED rear brake lights and center high-mounted stoplight (CHMSL)
- Power sliding tinted glass moonroof with one-touch auto-open/close, tilt feature and sliding sunshade
- Power rear liftgate
- Roof rails (Available)
- Integrated rear spoiler
- UV-reducing solar glass
- Rear privacy glass
- Front door handle courtesy lights
- Power adjustable, heated outside mirrors
- Flat-blade front windshield wipers
- Rear window intermittent wiper and defroster with timer
- Aluminum front doorsill plates
INTERIOR FEATURES:
- Infiniti intelligent Key with Illuminated Push Button Ignition
- Tri-Zone Automatic Temperature Control system with microfilter
- Rear-seat heating ducts under first and second-row seats
- Rear console-mounted and third-row side trim heating and cooling vents
- Power windows with illuminated switches and one-touch auto-up/down with auto-reverse feature
- Power door locks with automatic locking feature
- Retained accessory power for windows and moonroof
- Sequential welcome lighting illuminated entry system and overhead ambient light
- Front sun visors with illuminated vanity mirrors and extensions
- Overhead sunglasses storage
- Dual overhead front map lights, rear-seat reading lights
- Dual front seatback map pockets; front door pockets
- 8 cup holders and 6 bottle holders
- Front center console with armrest, dual-level storage compartment, 12-volt power outlet, auxiliary input jacks and USB connection port
- Second-row folding armrest
- Outside temperature display
- Front and rear carpeted floor mats
- Cargo net tie-down anchors in cargo area
Seating and Trim:
- Leather-appointed seating
- 8-way power driver's seat with adjustable lumbar support
- 6-way power front-passenger's seat
- Dual-occupant memory system for driver's seat, steering wheel and outside mirrors, linked to individual intelligent Keys
- Entry/exit assist for driver's seat and steering wheel (Available)
- Heated front seats
- Climate-controlled front seats (Available)
- 60/40-split folding, sliding second-row bench seat
- Multifunction second-row seat with easy of third-row entry/exit, including non-removal babyseat mode
- 50/50-split folding third-row seat with recline
- Kasane Washi interior trim
- Maple interior accents (Available)
- Leather-wrapped steering wheel and shift knob
Audio Systems:
- 6-speaker audio system, including AM/FM/CD with MP3 playback capability, Radio Data System (RDS) and speed-sensitive volume control
- Single in-dash CD player
- Streaming audio via Bluetooth® wireless technology (Available)
- USB connection port for iPod® interface and other compatible devices
- XM® Satellite Radio
- Illuminated steering wheel-mounted audio controls
Instrumentation and Driver Controls:
- Fine Vision electroluminescent gauges
- Infiniti intelligent-View Display
- Power tilt and telescopic steering column
- Bluetooth® Hands-free Phone System
- Infiniti Controller for audio, climate control, fuel economy, maintenance, and comfort and convenience features
- 7-inch color vehicle information display
- Infiniti Hard Drive Navigation System with 8-inch WVGA color touch-screen display, Lane Guidance and 3-D building graphics (Available)
- Infiniti Voice Recognition for audio, navigation and vehicle information systems (Available)
- XM NavTraffic® with Real-Time Traffic information (Available)
- XM NavWeather™ with Real-Time Weather and 3-day forecast (Available)
- Zagat Survey® Restaurant Guide (Available)
- RearView Monitor
- Around View® Monitor with Moving Object Detection and Front and Rear Sonar System (Available)
- Auto-dimming inside mirror with HomeLink® Universal Transceiver (Available)
- Cruise control with steering wheel-mounted switches
SAFETY FEATURES:
- Infiniti Advanced Air Bag System (AABS) includes dual-stage front supplemental air bags with seat belt sensors and an occupant-classification sensor which adjust their inflation rate depending on crash severity and seat belt usage. If the front-passenger's seat is empty, a sensor will deactivate the air bag
- Driver and front-passenger seat-mounted side-impact supplemental air bags
- Roof-mounted curtain side-impact supplemental air bags with rollover sensor for first- second- and third-row outboard occupant head protection
- 3-point height-adjustable front seat belts with pretensioners and load limiters, driver's seat Emergency Locking Retractor (ELR) and passenger's seat ELR and Automatic Locking Retractor (ALR)
- Rear 3-point seat belts with ELR and ALR
- Zone Body construction with reinforced passenger compartment and front and rear crumple zones
- LATCH System (Lower Anchors and Tethers for CHildren) helps simplify proper installation of compatible child restraint seats. (Second-row outboard only)
- Child seat top tether on second-row center seat and third-row passenger's side seat
- Snug Kids®. The first venture of its kind, Snug Kids® is our online guide to selecting and correctly installing a child restraint seat for your infiniti automobile. Our safety engineers evaluated numerous child restraint seats, installing them in every infiniti car and SUV. Visit infinitiUSA.com/snugkids to view or download the results
- Electronic Brake force Distribution (EBD)
- Brake Assist (BA)
- 4-wheel Anti-lock Braking System (ABS)
- Blind Spot Warning (BSW) helps alert the driver to a vehicle detected in the blind spot area (Available)
- Forward Collision Warning (FCW). Using the JX's laser rangefinder, this available feature helps alert the driver of an imminent collision by providing a visual and an audible warning. (Available)
- Intelligent Brake Assist (IBA). This available active safety feature continuously monitors and analyzes closing speeds to a vehicle ahead or to a stationary obstacle. If the driver does not adequately respond to the Forward Collision Warning and a collision cannot be avoided, IBA will automatically engage the brakes to help reduce collision speed and impact, thus mitigating the consequences of the accident. (Available)
- Lane Departure Warning (LDW) and Lane Departure Prevention (LDP) Systems. LDW sounds an audible warning when you start to drift out of your lane and LDP lightly applies the brakes to help ease you back between the lines.
- Traction Control System (TCS)
- Vehicle Dynamic Control (VDC)
- Slide-away brake pedal assembly
- LED taillights. Lighting faster than conventional taillights, they help give drivers behind you a quicker indication of your braking.
- Tire Pressure Monitoring System (TPMS) with individual tire pressure display and Tire inflation indicator provides specific information for each tire and low pressure warning
Security:
- Remote keyless entry system with selective unlocking of driver's door or all doors
- Remote power-opening of windows; closing via exterior door lock
- Infiniti Vehicle Immobilizer System embeds an encoded transponder chip into the ignition key. The engine control computer will not allow the engine to start without the correct key and transponder.
- Vehicle Security System
- HomeLink® Universal Transceiver offers control for compatible garage doors and home security systems (Available)
- Auto Hazard Warning Signal
POWER:
Engine
Valvetrain
Intake System
Fuel Economy
Horsepower
265 hp @ 6,400 rpm
Torque
Transmission
Drive Type
- Front-wheel drive
Tow Capacity
3,500 lbs
HANDLING:
Steering
Suspension
Wheels and Tires
EXTERIOR FEATURES:
INTERIOR FEATURES:
Seating and Trim:
Audio Systems:
- RearView Monitor
SAFETY FEATURES:
- Brake Assist (BA)
Security:
