Infiniti claims that the JX will have a V6. I am guessing it will be based on the VQ37 motor from the 2011 G37.
VQ37VHR 3.7 L 328 hp (245 kW) 269 ft·lbf (365 N·m) V6
It is usually mated with the 6 speed manual or the 7 speed auto. Thought Infiniti states the transmission from the Infiniti JX has new features "continuously variable transmission".
A continuously variable transmission (CVT) is a transmission that can change steplessly through an infinite number of effective gear ratios between maximum and minimum values. This contrasts with other mechanical transmissions that offer a fixed number of gear ratios. The flexibility of a CVT allows the driving shaft to maintain a constant angular velocity over a range of output velocities. This can provide better fuel economy than other transmissions by enabling the engine to run at its most efficient revolutions per minute (RPM) for a range of vehicle speeds. Alternatively it can be used to maximize the performance of a vehicle by allowing the engine to turn at the RPM at which it produces peak power. This is typically higher than the RPM that achieves peak efficiency.
