1 - 20 of 30 Posts
2013 Infiniti QX - Setting Button
SETTING Button
Use this button to customize the settings of the various electronic systems in your vehicle. You can adjust settings for Navigation, Audio, Phone, Bluetooth®, Volume and Beeps, Rear Display, Driver Assistance and Others by pressing the SETTING button.
Use the touchscreen to choose a setting function you wish to adjust.
Selecting "Navigation" will provide options for setting the Navigation System.
Select "Audio" to adjust features such as Bass, Treble, Balance, Fade and Speed Sensitive Volume.
The "Phone" and "Bluetooth" screens provide numerous options for operating your Bluetooth® Hands-free Phone System, including phonebook and ringtone settings.
The "Volume and Beeps" menu allows you to adjust the volume and status of the Guidance Voice, Phone options and Beep functions.
The "Rear display" key allows you to control the items that appear on the left or right display. Select the "Auto Display" to set the rear displays to always power on when a movie is played from
a DVD or USB device.
If so equipped, you can adjust the "Driver Assistance" settings for Forward Collision Warning, Lane Departure Warning, Distance Control Assist and Lane Departure Prevention.
Selecting the OTHERS key and then selecting "Display" will allow you to adjust the color theme, brightness, contrast and background color.
Selecting the OTHERS key and then "Clock" enables you to set and adjust clock functions.
Select "Others" to access the "Language and Units" menu. This feature lets you change the language and measurement unit used in the system.
Discussion Starter · #2 ·
2013 Infiniti QX - Map Button
Map Button
Your Navigation System contains mapping of all major cities and roads to keep you on track. Once you've chosen a destination, the computer calculates a route, with time and distance to your destination.
Your position is constantly updated and guidance provided, as well as information to nearby restaurants, hotels and other stops.
Press the MAP button to display the current location's map screen. Then touch MAP MENU. A menu will come up.
To access a particular map view, Select "Map View" and then "Change View" on the touch screen.
Select 2D, SPLIT 2D, BIRDVIEW, or SPLIT BIRDVIEW format.
The 2D VIEW shows a map in the two dimensional form that is similar to a road map.
The SPLIT 2D, also shows two maps in the two dimensional format, but shows a closeup of one and a wider view of the other.
The BIRDVIEW map makes a route more recognizable because it elevates the landmarks and provides a panoramic view over a long distance.
If you choose SPLIT (BIRDVIEW) you can look at both views at once on a split screen.
Use the arrows on the touch screen to move around a map. When you start moving, a cross pointer appears. Stop when the pointer is where you want it and press ENTER.
To view the map in greater detail, touch this KEY then press ZOOM IN until you achieve the desired setting.
To view a wider area, press ZOOM OUT. If you press and hold the ZOOM button in either direction, you'll get continuously closer or farther away map views.
The scale information will disappear after neither ZOOM setting has been used for several seconds.
2013 Infiniti QX - Navigation System Owner's Manual
Your Navigation System Owner's Manual supplements this brief introduction, covering many more topics in greater detail.
It contains system information, technical information and a useful Troubleshooting Guide. This special Owner's Manual will help you become familiar with all the features of your Navigation System, offering you maximum efficiency and convenience as a traveling companion, guide and aid.
2013 Infiniti QX - Voice Guidance
Voice guidance gives navigation directions verbally for the route set and can be activated or deactivated.
To turn voice guidance ON or OFF press the ROUTE button, and then select the GUIDANCE SETTINGS key using the touch screen.
Choose the GUIDANCE VOICE key by pressing the touch screen. The indicator illuminates if voice guidance is activated.
To adjust the volume, touch GUIDANCE VOLUME and touch the PLUS or MINUS key to raise or lower the volume.
To hear a repeat of route instructions, press the VOICE BUTTON.
2013 Infiniti QX - Day/Night Button
Day/Night OFF Button
The DAY/ NIGHT OFF button displays alternate views of a day screen and a night screen. Press this button for more than two seconds to turn the display OFF. Press again to turn the display ON.
You can also adjust the screen brightness in either Day or night setting by pressing the Day/Night OFF button and then turning the INFINITI controller to increase or decrease the brightness.
2013 Infiniti QX - Vehicle Dynamic Control (VDC) and Traction Control System
Vehicle Dynamic Control (VDC) and Traction Control System (TCS)
The Vehicle Dynamic Control (VDC) system uses various sensors to monitor driver inputs and vehicle motion. Under certain driving conditions, it controls brake pressure and engine output to help the driver maintain control of the vehicle. VDC should remain ON when driving, except when freeing the vehicle from mud or snow.
When you push the VDC OFF switch located on the center console behind the selector lever, an indicator light will illuminate. If you have turned OFF the VDC system, it will turn back ON when you push its switch a second time. Also, when you turn OFF and then restart your vehicle, the system will automatically come on again. Consult your Owner's Manual for further details on this system.
2013 Infiniti QX - Hazard Warning Flasher Switch
The Hazard Warning Flasher Switch is located in the center of the combination meter panel, below the center display. Push the switch on to warn other drivers when you must stop or park under emergency conditions. All turn signal lights flash and will operate with the ignition switch placed in any position. Push the switch again to turn OFF your hazard warning flashers.
2013 Infiniti QX - Child Restraint Systems
This vehicle is equipped with the Lower Anchors and Tethers for Children (LATCH) system, which includes lower anchors and top tether anchors. Please refer to your Owner's Manual to find out which seating positions are equipped with anchor points.
The Seat belts in your vehicle can also be used to secure the child restraint. For details on the proper installation of child restraint systems, please read the child restraint Owner's Manual and the special section in your vehicle's Owner's Manual.
You can also check the Infiniti Snug Kids® Child Restraint System Fit Guide for your vehicle. The Snug Kids® Child Restraint System Fit Guide helps parents confidently select a CRS that fits their vehicle and also provides valuable tips on the proper installation of a CRS. You can find the Snug Kids Child Restraint System Fit Guide at www.InfinitiUSA.com/snugkids.
2013 Infiniti QX - Seat Belt Warning Light and Chime
These important features remind you to fasten seat belts. The light illuminates whenever the ignition is in the ON position. It stays on until the driver's seat belt is fastened. The chime also sounds for a period of time unless the driver's seat belt is secured.
The seat belt warning light may also illuminate if the front passenger's seat belt is not fastened when the front passenger's seat is occupied.
It will not go on for a period of time after the ignition is turned ON, allowing time for the passenger to buckle up.
Discussion Starter · #10 ·
2013 Infiniti QX - Child Safety Rear Door Locks
Child safety locks help prevent the rear doors from being opened accidentally, especially when small children are in the vehicle.
The child safety lock levers are located on the edge of the rear doors.
When the lever is in the LOCK position, the door can be opened only from the outside.
Discussion Starter · #11 ·
2013 Infiniti QX - All-Mode 4WD®
All-Mode 4WD® (if so equipped)
The INFINITI All-Mode 4WD® system provides three driving positions so you can select the desired drive mode according to the driving conditions.
The 4WD shift switch is located on the center console behind the selector lever. Move the switch to the desired position to engage that drive mode.
Select the AUTO mode for driving on paved or slippery roads. The 4HI mode is used for driving on rocky, sandy or snow-covered roads. When maximum power and traction is required, such as on steep grades or muddy roads, the 4LO mode should be used.
The vehicle must be stopped with the brake applied and the selector lever in Neutral in order to shift between the 4H and 4L modes.
When a drive mode is selected, the 4WD shift indicator shows the position in the Dot matrix liquid crystal display. The indicator may blink while shifting from one drive mode to another.
If the 4WD warning light located in the meter comes on, the 4WD shift indicator turns off. If this light comes on or blinks slowly during operation or rapidly after stopping the vehicle for a while, have the vehicle checked by an INFINITI retailer as soon as possible.
Discussion Starter · #12 ·
2013 Infiniti QX - Power Outlets
Power Outlets
There are power outlets for small electrical devices, such as cellular phones, in four areas of the cabin -- the instrument panel, inside the front center console, the back side of the front center console and the cargo area.
To access a power outlet, simply open the cap.
The outlet on the back side of the front center console is a plug type outlet for use of a 120 volt, 150W power draw. It operates when the ignition switch is in the ON position and this main switch, located in the console box, is pushed to ON. Push the switch to OFF to cancel the power supply to the outlet on the rear of the front center console.
Please refer to the manufacturer's Owner's Manual supplied with your device for detailed information when connecting the device to an outlet.
Discussion Starter · #13 ·
2013 Infiniti QX - Interior Storage
Interior Storage
Your vehicle's glove box can be opened by pulling on this handle. When you want to lock or unlock the glove box, use your mechanical key.
Your vehicle is equipped with a console box located between the front seats. To open the compartment, push the knob and pull up on the lid.
If so equipped, an additional console box is located between the seats in the second row. Push the knob up and pull up on the lid to open.
The sunglasses holder is located above the rearview mirror and is opened by a push and release motion.
Your vehicle also offers a variety of hooks, storage bins, trays and map pockets located throughout the vehicle.
Discussion Starter · #14 ·
2013 Infiniti QX - AroundView® Monitor
AroundView® Monitor with Moving Object Detection and Front and Rear Sonar System
The Around View Monitor is a parking aid that provides views of your vehicle's position in relation to surrounding objects. There are cameras located in the center of the front grille, on the outside mirrors and above the rear license plate.
The Around View Monitor displays a combination of views with the ignition switch in the ON position.
• Bird's-eye View shows a top view all around your vehicle.
• Front-side View shows the area around and ahead of the passenger's side front wheel.
• Front-View shows the area directly in front of your vehicle.
• Front-Wide View shows a wider picture of the area directly in front of your vehicle.
• Rear View shows a picture of the area directly behind your rear bumper, and
• Rear-Wide View shows a wider picture of the area directly behind the vehicle.
Press the CAMERA button repeatedly to cycle through available view combinations or to return to the screen which was displayed before the CAMERA button was pressed.
With the ignition switch in the ON position and the shift lever in Park, Neutral, or drive position and the CAMERA button is pressed, the following views will be displayed in order:
• control panel screen
• a split screen of the Front-view and Bird's-eye View
• Front-View and Front side view and finally the
• Front-wide view.
When the transmission is shifted to REVERSE, the display monitor will display
a split screen of the Rear View and Bird's-eye View of your vehicle. If the camera button is pressed while in REVERSE the screen displays:
• Rear view and front side view,
• press CAMERA button again to see the Rear Wide view
• Press CAMERA button again to return to the Rear View and Bird's eye view.
When the transmission is shifted out of REVERSE, the display changes back to the original control panel screen.
The Front or Rear View monitor will display the approximate distance between an object and your vehicle with color lines.
• The second GREEN line designates an object is approximately 10 feet away.
• The first Green line designates an object is approximately 7 feet
• The YELLOW line designates an object is approximately 3 feet.
• The RED line designates an object approximately 1.5 feet
When the steering wheel is turned, predictive course lines are also displayed on the screen. These lines show the approximate path the vehicle will take. The predictive course lines move in conjunction with how far the steering wheel is turned.
The Moving Object Detection (MOD) operates only with the Around View Monitor activated. The MOD system can help inform the driver of moving objects surrounding the vehicle when driving out of parking structures, garages, or maneuvering in parking lots.
When the shift selector is in the drive position and the vehicle speed is below approximately 5 MPH, the MOD system detects moving objects in the Front-View or the Front-Wide view. With the shift selector in the REVERSE position and the vehicle speed is below approximately 5 MPH, the MOD system detects moving objects in the Rear-View or the Rear-Wide view.
A blue MOD icon is displayed on the screen when the MOD system is operative and a gray MOD icon is displayed when the MOD system is not operative.
If the MOD system detects a moving object near the vehicle, a yellow frame will be displayed on the information display screen and a chime sounds intermittently. While the MOD system continues to detect moving objects, the yellow frame continues to be displayed.
The MOD system will not operate if any door or the liftgate is open.
There are some areas in which the Around View Monitor is unable to display objects such as, an object below the bumper or on the ground. The Around View Monitor and MOD system is a convenience. These features are not a substitute for proper backing and driving procedures. For more detailed information, please see your Owner's Manual.
Discussion Starter · #15 ·
2013 Infiniti QX - Interior Lights
Interior Lights
Just above your rearview mirror are these map lights. Simply push the lens of either light to turn ON and OFF.
This three-position switch controls the interior lights.
• In the ON position, the map lights and rear personal lights will illuminate regardless of door positions.
• In the DOOR position, the map lights and rear personal lights will illuminate and remain on for a period of time when the ignition is placed in the LOCK or OFF position, doors are unlocked from outside the vehicle, or when any door is opened.
• In the OFF position, the lights will not illuminate regardless of door positions.
This switch controls the light in the cargo area. When the switch is in the ON position, the cargo light illuminates. The cargo light turns on with the liftgate open when the switch is in the center position. When the switch is in the OFF position, the cargo light will remain off.
Discussion Starter · #16 ·
2013 Infiniti QX - Conventional Cruise Control (Fixed Speed)
Cruise Control enables you to set a desired speed between 25 and 90 miles per hour -- and remain there until you wish to slow down, accelerate or stop.
Your vehicle may be equipped with Intelligent Cruise Control or ICC. If you have the ICC system, turn on the conventional fixed-speed cruise control by pushing and holding the steering wheel MAIN switch for longer than approximately 1.5 seconds.
If you do not have the ICC system, push the ON/OFF switch and the CRUISE indicator light will illuminate. Accelerate until you reach the desired speed. Then push down on the COAST/SET switch -- and release it. Your vehicle will operate at your selected speed.
If you need to pass another vehicle, assure that it is a legal maneuver, then press the accelerator pedal. Once you have safely passed, simply release the accelerator and your vehicle will return to the previously set speed.
To change to a faster cruising speed, push UP and hold the ACCELERATE/RESUME switch. Release at your desired cruising speed. If you push and quickly release this switch, each push will increase your set speed by about one mile per hour.
To reset at a slower cruising speed, push DOWN and hold the COAST/SET switch. Release when you have reached the desired slower speed. If you push and quickly release this switch, each push will decrease your set speed by about one mile per hour.
To cancel Cruise Control, push CANCEL, or tap your brake pedal. To resume cruising at your last set speed, push UP on the ACCELERATE/RESUME switch. To turn Cruise Control OFF completely, push the ON/OFF switch. For more detailed information, please refer to your Owner's Manual.
Discussion Starter · #17 ·
2013 Infiniti QX - Automatic Anti-Glare Rearview Mirror
Your vehicle's inside rearview mirror has a feature that enables it to detect glare and automatically dim the mirror surface.
The indicator light will illuminate when the anti-glare feature is operating. Press this button to turn the anti-glare feature ON or OFF.
Discussion Starter · #18 ·
2013 Infiniti QX - Climate Controlled Seats
Climate Controlled Seats (if so equipped)
The climate control switch is located on the instrument panel. The climate controlled seat warms or cools the front seats by blowing warm or cool air from under the surface of the seat.
With the ignition ON, turn the switch to the left to cool the seat and to the right to heat the seat.
When the switch is set to heat or cool the seat, an indicator light will illuminate.
When leaving your vehicle -- be sure to turn OFF the climate control seat switches by turning the switch back to the center position.
Your vehicle is equipped with second row heated seats the switches are located on the back of the center console. Push the switch to either High or Low to turn the heater on, and the indicator will illuminate on the switch. When leaving your vehicle -- be sure to turn OFF the rear Heated seat switches.
Discussion Starter · #19 ·
2013 Infiniti JX - Heated Steering Wheel
The heated steering wheel system is designed to operate only when the surface temperature of the steering wheel is below approximately 68 degrees Fahrenheit.
To warm the steering wheel, your ignition switch must be in the ON position. Push the heated steering wheel switch located on the lower instrument panel, below the heater and air conditioner controls. The indicator light will come on.
Push the switch again to manually turn off the heated steering wheel.
The system will cycle on and off to maintain a temperature above 68 degrees. The indicator light on the switch will remain on as long as the system is activated.
Discussion Starter · #20 ·
2013 Infiniti JX - Power Tilt/Telescopic Steering
Power Tilt/Telescopic Steering Column
Use this switch on the left side of the steering column to adjust the steering wheel to the desired position. Push the switch up, down, forward or backward to move the steering wheel in the corresponding direction.
With the automatic drive positioner activated, the steering wheel will move up automatically when the driver's door is opened and the ignition switch is placed in the LOCK position. It will move back into position when the driver's door is closed and the ignition switch is pushed. laced in the ACC position.
1 - 20 of 30 Posts
