I have a bunch of questions on what the manual says about the various intervention systems. So this question is laden with acronyms. So bear with me
Can somebody tell me what the "Dynamic Driver Assistance switch turns on and off"?
From the manual on pg: 5-72 I see the following
The dynamic driver assistance switch is used for the LDP, DCA and BCI systems.
But I believe I read somewhere else that BCI is always on (maybe I am wrong)
* Is there anyway to have BCI always on and enable/disable LDP, BSI, DCA alone using the Driver Assistance Switch?
Also the manual says the following about DCA on the same pg: 5-72
When the DCA system is not necessary, be sure to turn off the dynamic driver assistance
switch. Using the system when it is not necessary may result in an accident.
* Does everyone turn the DCA on only when they need it?
* What if I want to have LDP, BSI and BCI always on and enable DCA on/off as I need it.
I am guessing I will have to go into the menu to do this and can't be done with the Driver assistance switch. Am I right?
