The loaded AWD JX that we leased had the $200 cargo package from the factory, so we had to take it. After playing around with the parts, I wish I could RETURN TO SENDER.
First Aid Kit - Nothing you can't get for $10 yourself at the drugstore and throw it in a small bag.
Cargo Area Protector - flimsy piece that velcroes across the whole floor of the rear with 3rd row down. Looks like the velcro will eventually ruin the carpet as velcro invariably does after multiple applications. It can stay in place when you put up the 3rd row, but then the door to the cargo hold behind the third row is hard to open or keep open for the time you have bags sticking up out of it.
Cargo Dividers - tow plastic boards that sit in the cargo hold to divide up the space next to the subwoofer. Now the spaces are too small for a standard paper grocery bag, which I think would be the most common use of the area. Useless unless you have loose items or a very small bag.
Tonneau Cover - a stretchy tarp that hooks by six spots along the underside of the third row windows and then down to the cargo hold door. It's a pain to put on and take off as you need to access the hooks from both rear doors and then the rear liftgate. I was used to a retractable roller with the cover in our MDX. That was very easy to pull out and put back in. You only had to move it if you wanted the third row up. With this Infiniti cover, it seems easier to just throw a blanket over your cargo. You could use the cover in exactly that fashion.
My advice : SKIP the CARGO PACKAGE.
