Submersible mud pump
Product overview
WQ (QW) submersible mud pump is a new generation of pumps developed on the basis of the introduction of foreign advanced technology and the use characteristics of domestic pumps. It has the characteristics of high efficiency, energy saving, unique structure, anti winding, non blocking, automatic installation and automatic control. It has a unique effect in discharging solid particles and long fiber waste. It is applicable to chemical, petroleum, pharmaceutical, mining, paper industry, cement plant, steel plant, power plant, coal processing industry, as well as the sewage and dirties of conveying belt particles in the drainage system of urban sewage treatment plant, municipal engineering, construction site and other industries. It is also used for pumping clean water and corrosive medium.
WQ (QW) submersible mud pump adopts a unique impeller structure and a new type of mechanical seal, which can effectively transport solids and long fibers. Compared with the traditional impeller, the impeller of the pump adopts the form of single channel or double channel, which is similar to a bend with the same cross-section size, and has very good over flow performance. With a reasonable volute chamber, the pump has high efficiency, the impeller has dynamic and static balance test, and the pump has no vibration in operation.
Related products:
Liquid ring vacuum pump
What is liquid ring vacuum pump?
Liquid ring vacuum pump manufacturer
Other related products:
Platinum Rhodium Thermocouple
Heat Treatment Guide,Heat Treatment Equipment
Special Thermocouple For Waste Incinerator
Tags for this Thread
Posting Permissions
- You may post new threads
- You may post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
