SETTING Button
Use this button to customize the settings of the various electronic systems in your vehicle. You can adjust settings for Navigation, Audio, Phone, Bluetooth®, Volume and Beeps, Rear Display, Driver Assistance and Others by pressing the SETTING button.
Use the touchscreen to choose a setting function you wish to adjust.
Selecting "Navigation" will provide options for setting the Navigation System.
Select "Audio" to adjust features such as Bass, Treble, Balance, Fade and Speed Sensitive Volume.
The "Phone" and "Bluetooth" screens provide numerous options for operating your Bluetooth® Hands-free Phone System, including phonebook and ringtone settings.
The "Volume and Beeps" menu allows you to adjust the volume and status of the Guidance Voice, Phone options and Beep functions.
The "Rear display" key allows you to control the items that appear on the left or right display. Select the "Auto Display" to set the rear displays to always power on when a movie is played from
a DVD or USB device.
If so equipped, you can adjust the "Driver Assistance" settings for Forward Collision Warning, Lane Departure Warning, Distance Control Assist and Lane Departure Prevention.
Selecting the OTHERS key and then selecting "Display" will allow you to adjust the color theme, brightness, contrast and background color.
Selecting the OTHERS key and then "Clock" enables you to set and adjust clock functions.
Select "Others" to access the "Language and Units" menu. This feature lets you change the language and measurement unit used in the system.
Adjustable Head Restraints and Head Rests
Your vehicle's seats are equipped with adjustable head restraints and headrests that may help provide protection against injury in certain accidents.
The head restraint or headrest should be placed so its center is in line with the center of the ear.
To raise the head restraint or headrest, pull up. To lower, press and hold the LOCK knob while pushing the head restraint or headrest down. Please refer to your Owner's Manual for further details.
Your vehicle's front seats are equipped with active head restraints that move forward during a rear-end collision to absorb some of the forces that may lead to whiplash. The active head restraints will only operate in certain situations and will return to their original position after the collision.
Automatic Door Locks
For safety and convenience, your vehicle is equipped with automatic door locks.
All doors lock automatically when the vehicle speed reaches 15 miles per hour, and unlock when the ignition is placed in the OFF position.
The automatic door unlock system can be deactivated, however, the doors will not unlock when the ignition switch is placed in the OFF position. To unlock doors after deactivating automatic door locks, pull the inside lock knob or push the power driver's or front passenger's door unlock ICON.
Please refer to your Owner's Manual for detailed instructions on how to deactivate automatic door locks.
Power Seat Adjustments
Look for this switch on the side of the front seats. Simply slide it forward or backward and the seat will move in that direction.
This switch can also be used to adjust the height and angle of the seat. Move the front or rear end of the switch up or down to adjust the angle of the cushion. Then push down or pull up on the middle of the switch to adjust the height.
To recline the seat, push this switch backward until you've achieved the desired position. To bring the back upright, push the switch forward.
The lumbar support feature provides lower back support to the driver.
Move the switch forward or backward to adjust the seat lumbar support.
To adjust the second row seats, pull this lever, position the seatback as desired, and then release the lever.
The second row seats can be tipped forward for easy entry to and exit from the third row seats.
To enter or exit the third row seat, pull up on the lever located on top of the seatback. This is accomplished on vehicles equipped with the remote release type by simply pressing the remote tip-up second row seat switch, located on the lower combination meter panel below the heater and air conditioner controls.
The seatback will fall forward over the seat base. Now lift up on the seat base and tip the 2nd row seat forward.
To recline the third row seats, push and hold the rear side of this switch located behind the third row cup holders. To move the seatback forward, push and hold the front side of the switch.
There are two switches marked L for left and R for right on the passenger side of the cargo area that are used to fold down the left or right third row seats. With the selector lever in the Park position, press this side of the switch to fold down and this side of the switch to fold up.
Dot Matrix Liquid Crystal Display
Located between the vehicle's speedometer and tachometer is the dot matrix liquid crystal display. It displays operational information such as:
• Automatic transmission position indicator
• Distance Control Assist (DCA) system (if so equipped)
• Intelligent Key operation
• Cruise control and Intelligent Cruise Control (ICC) (if so equipped)
• INFINITI All-Mode 4 wheel drive (if so equipped)
• Trip Computer
• Tire Pressure
• Fuel Economy, and
• Other warnings and information
One of the Dot matrix liquid crystal display modes is the Trip Computer. When this button is pressed, the following modes will appear on the dot matrix liquid crystal display:
• MPG -- Displays the current fuel consumption.
• MPG/MPH -- Displays the average fuel consumption and speed since the last reset.
• TIME/MILES -- Displays the elapsed time and total distance the vehicle has been driven since the last reset.
• RANGE -- Displays the estimated Distance To Empty (DTE) the vehicle can be driven before refueling.
• OUTSIDE TEMP -- Displays the exterior air temperature including a low temperature warning feature.
• SETTING -- Allows you to set reminders for alerts and maintenance intervals or change the language and units used in the system.
- Press this button to cycle through the various setting modes.
- Press this button to choose the selected menu.
• WARNINGs -- If there are any.
For more information, refer to the "Instruments and controls (section 2)" of your Owner's Manual.
Just below the Dot matrix liquid crystal display, you'll find the odometer and twin trip odometer when the ignition switch is in the ON position.
The odometer records the total distance the vehicle has been driven, while the twin trip odometer records the distance of two individual trips. You'll see the TRIP RESET switch on the left side of the combination meter panel. Push it to change the display from trip A to trip B and back again. Push and hold the switch for more than one second to reset the selected odometer.
For complete details on how all of the Dot matrix liquid crystal display features work, please consult your Owner's Manual.
Related Threads
Infiniti JX Forums
21K posts
16.9K members
Since 2011
A forum community dedicated to Infiniti JX owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more!
